Noob looking for help. 2 x 12" pioneer TS-W304F
  • 2
jck
I have 2 12 inch Pioneer subs 1000w rmsr, 3500w max.
The problem is i have a Exile Xi1K amp that can output 1000w x 1 4 ohm mono, 500w x 2 2ohm stereo, 250w x 2 4 ohm stereo. I am just wondering if i am good to go or will i have any problems with running these subs. would i need a 2000w amp to run both these at 1000w each? Thanks!!
EDIT: I mentioned in the title TS-W304F i meant TS-W3002D4 12" Champion series pro
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
5
jck
jck
alberta
jck
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
