Noob needs help
ganjababyxx
Hey just got a new car with a head unit already installed.. Don't know if it has something to do with the wiring but when you fade all the way to the back sound comes out the front speakers and when you fade to the front you hear nothing at all.. I know a blown speaker sounds like crackling and at least a little sound will come out but we hear nothing at all... Don't know what to do from here or where to even start to check if its the speakers that have something wrong or if the wiring isn't right... Not even sure how to check the wiring at all so your advice would really help!
I got a new set of wires to replace anything that needs replacing....
Help!
start by figuring out what else is going on. is there an amp somewhere (either factory or aftermarket)? remove the head unit and look for RCA cables that would feed an amp. also look at connections in general. what make/model head unit? what make/model car? are there rear speakers?
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
987
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
ganjababyxx
ganjababyxx
United States
robert420
    Jun 1, 2024
    May 31, 2024
