Nvx xpld3k: Monoblock class d amplifier
  • 3
XplicitAudio
Pro Seller
PRODUCT OVERVIEW:
NVX's new XPLD3K amplifier is perfect for those looking for a high output amplifier. It boast an abundance of features such as subsonic and low pass filter, pre-amp outputs, and gain level control. The sleek design of the chassis combined with the illuminated badge makes this amplifier an eye-catcher. The XPLD3K monoblock includes a wired remote bass knob. Dual speaker terminals bridge the amplifier internally allowing for less confusion when wiring multiple subwoofers.
GENERAL FEATURES:
  • Class D Monoblock Amplifier with Bass Remote
  • RMS Power Rating:
  • 4 ohms: 1020 watts x 1 chan.
  • 2 ohms: 1900 watts x 1 chan.
  • 1 ohm: 3000 watts x 1 chan.
  • Dual Pulse Width Modulated (PWM) MOSFET power supply
  • Wired remote bass level control included
  • Mono channel operation
  • Master and slave input to combine multiple amps
  • 3-way protection circuitry (thermal, overload, and speaker short protection)
  • Dual speaker terminals simplify the hookup of multiple speakers
  • Variable subsonic filter (10-30 Hz, 24 dB/octave)
  • Variable low-pass filter (30-250 Hz, 24 dB/octave)
  • Input Sensitivity: 200mV-6V
  • Frequency response: 10-350 Hz
  • Heavy duty aluminum alloy heat-sink
  • Nickel-plated RCA level inputs
  • Nickel-plated screw terminals
  • LED power (green) and protect (red) indicators
  • Heavy duty copper layer double sided epoxy PCB
  • 0/1 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier
  • Dimensions: 10"W x 20.5"L x 2.5"H
NVX XPLD3K: Monoblock Class D Amplifier - Xplicit Audio
XplicitAudio
Pro Seller
XplicitAudio
United States
winkychevelle
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
