Odd Voltage drop.
  • 3
locomc
23
RI
Hey. I'm having a problem. My voltmeter on my dash has registered a massive voltage drop. Everything on my system runs fine, but I believe that the voltage drop is real and not the effect of a busted guage. I think it is my alternator that's going, but I decided it would be a very good idea to consult others. Any ideas?
LococMC.
The alternator is probably correct. Alternators like to go when spring turns to summer--I just replaced mine thursday. And, alternators do have a way of going bad gradually, not instantly (anywhere from a day to three days).
Your local auto parts store should do a test on it for you for free. Do it now before you get stuck on the highway.
Nope. I know it's not the ground. I have 2 8g and 1 2g ground coming off of my batteries. I also have two Optimas so I know it's not them either.
OH, nope. All three of those wires go to separate grounds. So i'm set. I'm getting the Ol' alternator replaced tomorrow. Thanks for the advie amigos.
Adios
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
locomc
locomc
RI
locomc
