Like I have the service Manuel from infinity I just need to know what wires go whereShould say on the amp. What amp is it? Post up a pic.
What side does voice out put go toLike I have the service Manuel from infinity I just need to know what wires go where
Thanks for your help clown if u bothered to read it I have power for both amps why the **** would I use a ground for a speaker wireAre you seriously hooking up speaker wire as your ground??? You may wanna stop what your doing before you blow something up. And seek professional help.
https://www.planetaudiousa.com/product/car-audio-sound-system-auto-4-channel-amplifier-planet-audio-ac1200-4/
No, really, your posts so far make it very clear you don't have any business trying to do this yourself.Thanks for your help clown if u bothered to read it I have power for both amps why the **** would I use a ground for a speaker wire
that hookup looks shady to me as well!Are you seriously hooking up speaker wire as your ground??? You may wanna stop what your doing before you blow something up. And seek professional help.
Don't be a douchebag. Whether or not you realize it, this is actually really good advice. We can clearly see in those pictures, you have speaker wire, wired up as either the ground or as the remote in. Either way, along with your question, you have no clue what you are doing. This is not even a 1, this is about a .5 out of 10 on a difficulty scale, and if you don't know this then there is probably something else wrong with your setup. There may be something else so simple, but so wrong that could burn down your vehicle. If you don't know what a speaker connection on an amp looks like, and don't know what "12v, ground, remote in" mean, you should stop trying to install this yourself.Thanks for your help clown if u bothered to read it I have power for both amps why the **** would I use a ground for a speaker wire
