On and off static/vibration
  • 4
Robin78
CarAudio.com Newbie
Hi there. Hoping someone can point me in the right direction before I have to take it to the shop.
Bought a used Volvo xc60 (2013) radio sounded amazing for the base model. Suddenly it would sound staticky at times, maybe vibrating a little, but sounded less “noisy” at higher levels. It would be that way for a short trip and then it would be normal again. 🤷‍♀️
seems like now it’s all the time. I’m not sure if this is a speaker issue? It comes from all for speakers, but not the tweeters. I’d hate to buy four new speakers and this not be the issue. Is it common for all four to go at the same time?? Any insight is welcome!!!
Thanks
I would remove the door panels or speaker coverings. 7+ years can do damage to factory speakers. Inspect them as it is free to do. Tweeters may have some form of crossover and or protection on the from the manufacture which may be why the noise doesn't come from them.
Older Silverado and Avalanche models had a similar issue. Moisture would get inside the doors and rust the speakers from the back. They would all bust within a short period of each other.
6
154
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
828
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
Robin78
CarAudio.com Newbie
Robin78
North Carolina
Louisiana_CRX
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
