oOP'S. wHAT HAVE i DONE??
imthedaddy121
I take out my sub and amps on a night for security, When I was wiring them this morning I
mad a BIG mistake, yes I wired the live to the neg, and vice-versa ( the fuse on the amp had
been removed) but the live was "live" when I plugged up the phono lead from the head unit
my amp started to smoke, I pulled of all the wire immediately . What damage could I
done?? //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
1) you let the magic smoke out, amp's dead.
2) isn't it more conspicious to remove your amp and sub nightly??
3) oops doesn't have an apostrophe, idio't.
Most amps have protection circuits that will protect the amp from reversed polarity, try hooking it up and see if it still works.
If it no longer works then you have just found out the hard way that your amp does not have this protection circuit and you will need to get the power supply repaired.
I take out my sub and amps on a night for security, When I was wiring them this morning Imad a BIG mistake, yes I wired the live to the neg, and vice-versa ( the fuse on the amp had
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif How lucky was I. Every thying works ok!
Good, you're learning! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So, I wonder where all that smoke came from. Did you open the amp up yet?
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
imthedaddy121
imthedaddy121
Leeds, UK
THUNDERBIRD
    Jun 1, 2024
    May 31, 2024
