I have a set of PPI A2.65c's that im running off of a Kicker zx550.2. The speakers are rated at 130 rms. The amp puts out 205 rms at 4 ohms, and 275 rms at 2 ohms. But these are 3 ohm speakers according to the box. So will they be getting between 275 rms and 205 rms? Or how does that work?
Also, i currently have the amp gain nearly all the way down. Will be setting it by ear tomoro. So obviously they are being overpowered. Im gona turn gain all the way down and play a song and set the HU volume on 35/50. I will then turn up the gain until i hear distortion. Will the speakers distort simply if they are receiving too much power? Or do they only distort if the amp is clipping? will the speakers blow/get damaged over time if they are recieving around 200 rms but i hear no distortion?
Also, which is better: Using the crossovers (HPF LPF) on the HU or the amp?
Thanks for the help.
http://www.sonicelectronix.com/item_6749_Kicker-ZX550.2.html
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.sonicelectronix.com%2Fitem_24362_Precision-Power-PPI-A2.65C.html&ei=dm17UK-KKZHo8QSO84DgDA&usg=AFQjCNFoHQDckdTsgkwIpD92ikPvZ8y9dg&sig2=1bZ5NHkmhOJkMvx_y85w5w
