PAC RadioPro5 = No Power Windows/ Locks & No Gauges?
  • 2
ahopkins321
CarAudio.com Newbie
I installed the RadioPro5 hooked up to an older Pioneer avh-p3200bt double din in my 04 GMC Sierra Denali with Bose and Onstar.
Everything worked perfectly for the first few days then I didn't drive the truck for about a week.. I went to fire it up yesterday, battery was dead.. Stuck the battery on a charger, let it charge until today and it fired up but now I get no sound from radio, the radio no longer turns off when the truck turns off, the power windows and door locks no longer work, all gauges on the dash stay at bottom position except speedometer and tach..
I pulled the new radio and pac harness and plugged in the factory radio and EVERYTHING works again so the problem has to be isolated to the PAC..
Any thoughts on what could be happening?
Any help would be greatly appreciated!
It sounds to me like you've got a short behind the DIMM in your wiring harness most likely. My guess is that the positive cable is some how getting grounded and it worked at first because it's spliced to ground rather than a direct connect. Double check your wiring colors and that the harness is the correct one. If you're having issues confirming this you can also just check the resistance on the harness power pin with it unplugged and either the ground pin on the harness and/or the ground terminal that normally hooks to the chassis and the inner metal surface of the DIMM slot.
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that...
7
Yeah, so many OEM bass remotes are useless the way the control the bass boost circuit. Boosting 40hz or whatever frequency, is again nearly...
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
222
ahopkins321
CarAudio.com Newbie
ahopkins321
Houston, TX
Lasherž
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
