PG Ti600.2 NEED HELP!
drtjmpr909
Nothing beats a tight box
315
Pa
I have a PG Ti600.2. One of my favorite amps. The cooling fan recently stopped working, and now the amp overheats. Does anyone know where I can find a replacement fan?
Also, would running this amp at a 4ohm mono load with no fan cause it to overheat?
I love this amp myself,I have two running in my car one for the components and for the mids,the best thing to do is call PG and they will take care of you.Great customer service.
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
450
347
755
drtjmpr909
drtjmpr909
Pa
smgreen20
    May 16, 2024
    May 16, 2024
