Pioneer DEH 1600 Remova
!WORM!
Ok... I just bought 2 12' subs and an amp... I can not remove my headunit from ym dashboard for some reason... It just will not come out... Someone told me there is grips in the sides and i have to stick something up the side and that didnt work either.... i took apart my whole dashboard and it just wont come out... Can anyone help me?
-Thanks,
!WORM!
yup, you need the two L shaped 'keys' that Pioneer makes to get that out. Any shop that carries Pioneer equipment will have probably 10 sets... should do the trick.
someone told me i should be able to stick any thin piece of metal in the side of my radio and that should work. But i couldnt seem to do that
yeh i have to really long pieces of metal but i dont know where the things that have to release are... I am not able to stick anything in the middle there are like 2 metal plates blocking the middle and then the top and bottom corners wen i put it in there it dont work
Hey i got it out. The problem was that the pins that release wen u put the flat piece of metal in were screwed down... Whoever installed it didnt want it to be easy totake out so i had to unscrew that wen i took the whole dash apart...
!WORM!
!WORM!
New York
!WORM!
    May 24, 2024
    May 23, 2024
