Pioneer head unit
  • 3
Is the pioneer premier degree-600ub good, I'm getting an offer on an almani 4 channel amp to trade with.
if your goal is to just have a working dirt cheap head unit then it will be fine. If your goal is actual good sound quality, that head unit is outdated junk due to zero tuning options compared to what you can get for 99 dollars nowadays.
i can't believe the JVC is that ****** for only 450. granted its only one 32bt dac still.
single 32 bit is still better than multiple 24 bits imo. my home theater receivers prove that by far. You really got me thinking about swapping to a double din because i've been wanting to swap to a double din for a long time now.
i"ll bet you money. 100 bucks. that you get the x730 or v830 and get high res recordings you 1 have an instant SQ upgrade and 2 won't go back to pioneer.
now to get you to run some zapcos and some real low distortion mids/highs..
This looks like they went in and rewired some wires. 12 volts or a little less than 12 volts. When not enough volts are going through it, your...
6
You need to re-phrase the question. Are you trying to use active bi-amplification via outboard amplifiers or do you just want the recommended...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
460
SuperScion9000
San tan valley, AZ
SuperScion9000
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
