Plans on new sub & amp combo, need advice
The cab 1600 amp is a pretty good budget amp that puts out rated power, which is what you want. The sundown subs are top notch subs. Would be a nice combo, I just hope you have a decent sized alternator in that ranger.
That does sound pretty simple
Sent from my SM-G930V using Tapatalk
looks like the guys did a good job steering u to better equipment.. yeah u need good amp $200 or so cab ok or even skar 1500 $180 is ok budget amp E's are good subs u could look at soundqubed hds3.1's.. just make sure u let us tell u what voice coil (ohm load) subs to get so u don't order wrong ones..
It's a stock alternator haha. I might have to upgrade it too
I agree 2 E-12's on a CAB should do ok... lol... a decent AGM, +120A alt and big 3 would be the minimum for a daily IMO.
Also guys what gauge of wire would you recommend running?
at a 2 ohm load on that amp it is capable of 1200+ rms. I would get the thickest true gauge wire you can afford that is ofc. Try to get 0 gauge, true 4 gauge is really cutting it too close with that amp, even at 2 ohm load..
**** that thick of wire!
0ga for power and ground maybe 4ga for alt wire... if you are gonna upgrade someday (most will) that 0ga will be needed at 1 ohm. And the wire is something you'll want to do only once.
Thanks
np, post link to the cable before you buy some. A lot of cable out on the market is not true gauge wire, they will put a thick coating around the wire and make you think its bigger when its not.
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
451
470
Haywardr23
Castle Dale, utah
shredder2
    Jun 1, 2024
    May 31, 2024
