please help with wiring
  • 4
I have the nvx jad 800 4 channel amp:
4 ohms: 125 watts x 4 chan
2 ohms: 200 watts x 4 chan
Bridged, 4 ohms: 400 x 2 chan
I have a pair of Alpine components:
Peak Power: 330W
RMS Power: 110W
4 Ohms Impedance
I have a Pioneer DEH-x6900BT head unit:
front, rear and sub preouts
Questions:
I'm only running the pair of components up front off of this nvx amp. how do i bridge the amp and get a 4 ohm impedance? or is that not possible? Should i not bridge the amp at all? do i need to use both the front and rear preouts to be able to fade to the left or to the right? if so how? Thanks to all that reply.
its all answered in the owners manual which should have came inside your amp's box or google search online.
ive looked in my manual and searched extensively on google for "how to bridge 4 channel amp with pair of 4 ohm components" but i cant find anything because most people use two sets of speakers. I'm just using the front pair. so correct me if I'm wrong, if i wire the speakers in parallel ill get a 2 ohm load? is there anyway to wire them to the amp and get a 4 ohm load bridged? wouldn't running the amp at 2 ohm cause it more stress?
its easier if you just get rid of the passive crossovers completely and just run active with front two channels for tweeters and rear channels for mids. it'll be 2 channel stereo mids and highs. No front or rear with passive crossover garbage. This is assuming your head unit is active capable though.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
You're the man. Give me your number so I can just call you the next time I have a question instead of having to make a post here. Lol. Thank you...
8
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
cparker2591
albany, OR
Papermaker85
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
