Port not on the same side as sub
  • 4
i don't know any programs that are specific to placement of the woofer. Bass Box Pro or Term Pro would be your best bet if you set on a program. They have other calculators out there as well that work pretty good.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
790
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
969
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
944
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
JJ30
JJ30
Hillsboro, OR
Buck
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
