Port ?
  • 5
Not that it pertains to this too much, but high-peak narrow-bandwidth burp boxes have ridiculously short ports. DD Belgium's looks to be about 3", lol:
dB-drag SS NW project 2012 from "Team DD Belgium" - SPL & Streetbass - Talk Audio
That box looks like a dog house.
Ya, you can do just a straight port. When doing a slot, half the ports width needs to be taken off the end of the port because the surrounding walls extend the port basically.
Can you explain that more? I'm very interested, actually
There is a % of the port width that still acts as port length. I forget the % exactly but if a port is say 5" wide, up to say 5.5" width can still be considered port length.
Same with flared aeros or kerfed ports.
Cool, thanks!
Looking straight on at that "box" you posted, the right hand wall is part of the "port". While the baffle side is short, the long side still holds a column of air against it. SO to figure out the effective port length, you take the depth of the shorter side and add half a port width.
Or in other words. Sketch up a top view of that box, then draw a line at a 45 degree angle from the back of the baffle (right at the edge of the port) extending to the right hand wall of the port... that is the port volume/length that the speaker/box "sees".
Or in other other words. If that "port" was in the center of the box, it would need to extend about a foot deep into the box to load the same as it is now due to the driver's side wall. I tried to sketch it up in gimp but it's saving in some oddball file format. LMK if you don't follow I'll boot up windows and use Paint.
Thanks, that was a great explanation! Good to know
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
793
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
973
947
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
malandrin4o8
malandrin4o8
San Jose, Ca
adulbrich
    Jun 1, 2024
    May 31, 2024
