TypEL 10+ year member
Car - 94 tt Supra
Going to be adding front speaker only, no rear. I have a good deal on some fronts, but not sure if i should or not...
1 X Alpine type X 4" Componenet set
1 X Alpine type X 6.5" component set
(last year models, brand new for 150 cdn set)
Subs/amps
2 x 12" Mb Quart (original quart stuff) subs
2 x KX550.3 Amps
This is my plan....
Install the 6.5" speakers in the stock door locations, and install the 4" speakers + both tweeters (so 2 per side) in kickpanels. I would use all the alpine crossovers. One amp would power the 6.5" comp set, and the other the 4" comp set.
I would also be using an MTX LSX2 Crossover (maybe a line driver for the subs as well).
Questions...
1) Does this setup make sense, or should i ditch the 4", and just stick with the 6.5;s???
2) If i decide to go ahead with my plan, do i use the alpine crossovers, or does the MTX LSX2 replace the alpine crossovers?????
3) I can pick up another set of the 6.5" components for the same price, would it be better to run 2 sets of 6.5" up front, or should i stay with the 4"/6.5" setup.
All doors would be insulated etc.
Subs/amps
2 x KX550.3 Amps
This is my plan....
Questions...
