power hx2
  • 2
A big one
Those monsters can handle 1000w easily. As far as a single amp let's see. An earthquake D2, maybe a planet audio 2400d. A Fosgate BD1500.1 would push them but not quite to there fullest potential. Of course you could strap a couple of BD1000.1 together
for roughly 2000w. That would be my choice. But of course I'm a power hungry fool
I just had another thought. The power hx2's are dual 2ohm. So you could wire them in parrallel for a 1ohm load each sub. The BD1500.1 might not be a bad choice. I have one in my wifes car that is running at 1ohm and it is putting out about 1800w. It's powering 2 power hx2 12's.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
470
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
697
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
510
timmy23
timmy23
Greenville SC
ramos
    Jun 1, 2024
    May 31, 2024
