Power wire causing amplifier output signal to distort?
Elmadus
Hi!
I’m having an headache with my cars sound system. It seems that no matter what parts i use, my amps output signal gets little distortion from somewhere.
So to open this up a little, here’s what i’m using:
HU: Kenwood KMM-BT304
Fronts: Skar Audio SK65C
Rears: Skar Audio SK65
4ch Amp: Rodek R4100n
Sub Amp: Alpine PDX-1.1000
Sub: Alpine Type-R SWR 1542D
The two amps are positioned under the front seats (Alpine under driver and Rodek under passenger) and the speakers are installed on the original speakers holes to keep the look of the car stock.
With this setup i’m getting small amounts of distortion from my speakers. This distortion appears on all volumes and it’s more and less present with different songs. It’s more noticable when sharper instrument’s are being played like piano or guitars.
This distortion doesn’t come out of the speaker outputs of the head unit, but putting sound through the amp makes it distorted, which could mean that the amp is the problem.
But before this setup i had a Skar audio RP-75.4ab amp with the same speakers and HU. And the same distortion existed with that amp aswell. Tried changing it to the current Rodek but the problem didn’t go away.
I’ve also tried a different head unit, but with the same result. I even tested it with my phone using an aux to RCA adapter to rule out the RCA cable. No luck with it either.
Trying different speakers wouldn’t even help it, same story with other kinds of speakers i tried on it.
I also checked all the connections that they’re properly attatched, grounding is good and so forth.
So the only possible thing that i think could affect the output is the power wire going to the amp? Or could something else interfere the signal that comes out of the amp?
Check your crossovers. Make sure they set properly
I’ve set my crossovers on the head unit for the speakers with a high-pass at 70hz, shouldn’t that be enough or should i put it up even higher?
And also i’ve put the crossovers on the amp at full so they don’t interfere with the HU:s crossover settings
what is the source your playing from?....bluetooth streaming, CD, thumb drive, Spotify, XM, Tidal, etc. etc.???? could be your source/recording
is Your power wires run separately than yours speaker wire and or rcas? If they’re all run down the same part of the vehicle that could be a problem.
They all run from different locations. Power wire goes under the right door scuff, speaker wires through the left scuff and RCA goes from the middle between the seats.
could be a tear in the speaker wiring and its grounding out slightly somewhere. Could also be RCAs bad. You already eliminated the amp and head unit out of the equation. There's only a few left. Also did you install the RCA on the opposite side of the power wire or the same side?
maybe you just got that golden ear and can hear distortion at .05 or lower.....can you hear others peoples thoughts inside their head?
Lol, i’d say the difference is noticable when compared to the speaker output of the HU itself, which doesn’t distort it. I can post an example if it’s noticable on camera.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Elmadus
Elmadus
Finland, Tampere
Jeffdachef
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
