Power Wire Opinions
  • 4
Clifff150
827
Texas
So I am going to install an IA 10.1 and a 4 channel (unsure which one) in my wife’s 4Runner. I already have plenty of 4 gauge from a smaller build I did. The IA will be mounted in the hatch area and the 4 channel will likely be under the passenger seat. Would y’all run a distro block by the battery that is 1/0 in and 2 4 gauge out and run one to each amp or would you run 1/0 to a distro by the passenger seat the 4 gauge to each?
Personally, I would fuse the 1/0 wire near the battery and Run it to a distribution block, as near to the components as possible. Then run the appropriate gauge from the block required by the component.
1/0 to the distribution block, then split as close to the components as possible. It makes for easier wire management and a cleaner build.
Only issue is that I’m going to have a hard time fitting that distro block under the rear seat. I’ll have to take a look with the amp I choose to see how much space I have. Unless I mount the 4 channel by the mono and just run longer speaker runs
The IA 10.1 is only 1200w. You'll be fine with a 5-10' run of 4 gauge if needed. Just use OFC and not CCA.
Use a fused distribution block.
Yeah it’ll be a fused distro block. Where is the best place to buy 1/0 flex wire online? I know welding wire is the best value but which vendor online?
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
6
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Clifff150
Clifff150
Texas
Clifff150
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
