PPI Phantom 900.4 4 channel 150 x 4 class D
donkryder954
PPI Phantom 900.4 4 channel 150 x 4 class D small and powerful
specs
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
2-Ohm Stereo, 4-Ohm Bridged Multi-Channel
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable
Band-Pass Crossovers
Source Input Selector
Direct Wire 8ga. Power & Speaker Terminals
0ga Reducer Terminal Included
Specifications
Amplifier Class: D
Number of Channels : 4-CHANNEL
RMS Power Output @ 14.4V :
Rating @ 4 ohms : 145 Watts x 4
Rating @ 2 ohms : 225 Watts x 4
Bridged @ 4 ohms : 450 Watts x 2
Low Pass Crossover : 50Hz - 5kHz @ 12dB
High Pass Crossover : 20Hz - 4kHz @ 12dB
Input Level Sensitivity : 200mV - 6V
Idle Current Draw : 1.34A
Damping Factor : 114
Input Impedance : 20k Ohm
S/N Ratio : 102dB
Fuse Rating : 45A + 35A
Dimensions (WHL) Inches : 6.75" x 2" x 10.9"
$175 shipped obo
I currently have the amp installed this is just a sample pic for reference ..
It pretty **** NICE ..has a lot of eq'ing ability ..it DOES RATED !! this is a really compact design but well built and does whats needed to be done ..more power and same sounding as my sundown 100.4 version B
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
I am wondering if anyone has heard or have information on the new PPI vertical PC amps. Are they good for a budget sq class D amplifier. Any...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
donkryder954
donkryder954
Ft. lauderdale ,fl (954)
donkryder954
    May 31, 2024
    May 24, 2024
