Precision Power PH2.65S Shallow components
  • 4
trumpet
Barry Schanz
1 set
Half of the set was used at low output for bench testing. The rest was out on display in our glass case un-powered. This is a surprisingly good sounding set for the money. The woofer is extremely shallow for those annoying locations where you just can't fit a big enough spacer to use a standard size woofer.
  • Power Handling 80w
  • Frequency Response 60-20kHz
  • Efficiency (1w/1m dB) 94dB
  • Woofer Mounting Depth 1.00"
Features:
  • Shallow Mount High Efficiency Component Set
  • Low Resonance Polycarbonate Frame
  • Only 1" Mounting Depth!
  • 1-Piece Polypropylene Dome Cone
  • High Strength Neodymium Magnets
  • 1.25" Aluminum Inverted Dome Tweeter
  • Passive 12dB Crossover Included
  • +/- 3dB Tweeter Attenuation Switch
  • PTC Tweeter Protection
$100
USPS Priority or UPS Ground shipping is included in the price for the lower 48 states.
All other locations require a QUOTE.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
477
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
699
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
    Jun 1, 2024
    May 31, 2024
