Problems with my sub and amp
  • 4
Alright so I have 2 12 inch kicker comp vr subs and a jbl gtr 1001 amp, the 2 subs combined should put out 800 Watts rms, and my amp is supposed to be 1000 Watts rms. But I was having an issue where my subs were cutting out a lot at pretty low volumes and I’m trying to figure out what the problem could be. I also did not install everything myself so I’m not sure how everything was wired, and I’m a little new to car audio but I know the basics. So anyways once I noticed it was cutting out, I watched my amp while I hade it turned up to a volume it typically cuts out at, and I watched my amp to see if the power light was turning off and to see if the protection mode light would come on. Whenever it cut out the protection light would flick on and off. It does it less when I’m parked than when I’m driving. And when it was installed I was told the battery lost power 4 times, so the problem could be with the battery but if it is with the battery then why is the amp protection light coming on when it cuts out? Is it possible my amp just isn’t good enough? That wouldn’t make sense though because it’s a jbl, I heard great things about the amp, nothing but amazing reviews so I’m kind of puzzled. So if somebody could help me out it would be greatly appreciated, I tried to be as specific as I could be, I’m sorry if I left any info out.
1st thing is check the ground on amp make sure it's tight and paint has been scraped from under it.. check gain what is it set at? do u have factory radio? also could be a wire on subs messed up touching another wire or coil on sub bad, u can try to unhook 1 sub see if amp does it with just 1 if not try the other one see if 1 sub is going out..
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
795
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
824
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
Treyce_93
Treyce_93
Oklahoma City, Oklahoma
BOOMINGRANDPA
audiobaun
    May 19, 2024
    May 19, 2024
