Product: AB 150.1 LNIB
nutxo
tacoma
Item(s) for Sale: 1. Product: AB 150.1 LNIB
2. Specs:
I OHM STABLE D CLASS MONO BLOCK AMPLIFIER * LOW LEVEL INPUT AND OUTPUT * FREQUENCY RESPONSE: 20Hz~350Hz * INPUT LEVEL: 0.2V~6V * VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT * VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT * VARIABLE BASS BOOST: 0~9dB AT 45Hz * REMOTE GAIN CONTROLLER * TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR * FUSE RATING-200 AMPS, LINKED FUSE RATE, 400 AMPS * EXTERNAL FUSES AND FUSE BLOCKS * 2900 WATTS RMS * Width: 9.5" * Height: 2.25" * Length:16"
3. Description/Condition: 9.5 cosmetic 10 mechanical. Never run below 13 volts and has only been run a total of maybe 10 hours.
4. Price: :350 plus ship, paypal only. No echecks.
5. Pictures: click the pic for video
My cars are broken. Nothing is wrong with it or I would have said so in the post ;-) No idea about warranty.
2900 @1. 1450 @2 and 800 @ 4. If you need more power hit me up. Got something maybe for you. These are under rated a bit too
Man what a beauty!!.Any Trades and PayPal on my end??Deposit till Fri even?LOL Work with me here..lol
I thank you sir for the info, and offering..I am sure to keep in mind my friend!
피크를 사용하지 않을 계획입니다.
Since about the time they started selling on Woofersetc and the other big online retailers, it's a product most everybody has seen or heard about...
32
3K
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
591
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
nutxo
nutxo
tacoma
BigBush78
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
