Proper break-in?
So, I've read a bit about people saying subs change in sound after they break-in. My question is if there is an actual break-in procedure for subs, or is this just a generic term for when the materials loosen up a bit?
Well for one, some companies will break in your sub before you ever get it or atleast stress test it at high volume/ power so its not like you need to take it easy from the start.
For two, all speakers sound different after break in, from subs to tweeters. No there is no break in procedure. Just play it. If you want to be nice, give it a minute and slowly crank the volume up. Its more of a, this makes me feel better to be nice to it for a second rather than logic.
It's mostly a generic saying,I beat my subs like Chris Brown beats a wh0re when they come out of the shipping box. But yes they change sound as the suspension loosens up.
some suspensions are much stiffer orginally with no play becasue they are coated with a type of resin that helps strengthen them. ive never seen a speaker get damaged from not breaking it in..
You don't have to break in a sub by using less power when you first install them.
After the suspension loosens up, the parameters will shift though, and it is considered "broken in"
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
436
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
Yeah I had lived in the sticks my whole life till a few yrs ago I moved to a different city to start over. Haven't had any break ins yet but...
6
Looking to buy and install an LOC. I got the basic functionality of it but not sure what I need. My set up is a factory Impala stock radio, 4...
Sguirrelfeather
Sguirrelfeather
Mountain Home, ID
Sguirrelfeather
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
