Proper Door Sound Deadening and You
is deadening the outer skin of your door necessary? im gonna use a deflex pad but im just wondering if i should deaden the entire outer skin too. the inner frame is already deadened.
yes yes yes yes yes yes yes
so many vibrations come from the outer skin of your door because it
a) deflects vibrations from your speakers all over the place causing distortion
b) is a relatively thin piece of metal and vibrates like mad. feel your door from the outside when you have your speakers up high, they hum and buzz like a thousand bees.
c) everyone says your supposed to, the above reasons are just thinking logically/realistically
Since we're on the subject, here is a pic of the speaker OEM speaker rings on my car...would anyone recommend using the MDF rings in addition to the method listed here?
Plastic resonates quite nicely if not deadned.
What i normally do is get rid of the stock rings ( most aftermarket speakers dont fit them) and make some custom MDF ones.
Plastic resonates quite nicely if not deadned.What i normally do is get rod f the stock rings ( most aftermarket speakers dont fit them) and make some custom MDF ones.
Ok, looks like I'll be doing some ring cutting. Thanks! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Well, I am going to try this out tonight. I will let you guys know what I find on saturday //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Update.
Tried the egg crate out. Works very well, mid range frequencys dont sound so "under water" I spent $1.50 on it too. Took about 30 min to install with silicone. Added more deadener to my doors. The clay worked pretty good at sealing the little inperfections I had leftover after the fist two rounds of deadeneing. Tried the plexi idea with a sheet of balsa wood I had lying around, but my doors are too large and the door skin wouldnt allow me to install it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
All in all tis a great tutorial.
I highly recommend deadening the inside of the outer door skin, it made a huge difference with mine. But I disagree with not using liquid deadener. It may take longer, yes, but with a brush you can reach areas that you can't with a mat.
Update.
bah i paid 30 bucks for my deflex pads, then again i do see water inside my door on rainy days. nice to see more positive comments on this stuff working, i have my liquid deadener on the way for my outer skin now.
to start off would it be affective if i just cover the outside of the door panel like this
cause i only have 24 sq ft (2 dynamat extreme dookits) will that still be affective?
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
444
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
251
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
594
squeak9798
Banned
squeak9798
USA
Gunk
    May 20, 2024
    May 20, 2024
