Prototype 3k @ 1 ohm
pro-rabbit
Moderator
12,639
OKC, OK
Prototype amplifier that was sent to us for testing years ago.
It is a little beat up looking but works perfectly.
$300 shipped conus
included
if it does 3k its good if it does 3.4k its still good, that little bit of power wont make much difference either way.. Buy it as a 3k amp.
---------- Post added at 10:56 AM ---------- Previous post was at 10:55 AM ----------
Saz 3000d ?
could seriously be one of 10-15 different amps, that will all do similar power
We tested it to do just over 3k @ 1.1 with 13.7 volts. I am lookong for more notes so I can check out the effecincy butbit has been a whilensince we tested this one.
As for the origin if the amp, sorry but that will have to stay unknown.
I figured at this price it should move pretty quick, just slowly clearing out some older items which we no longer have or need to hold on to.
It also lowers the amps efficiency and raises the current draw.
5
592
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
401
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
pro-rabbit
Moderator
pro-rabbit
OKC, OK
pro-rabbit
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
