Quesion about amp
  • 3
If the amplifier is rated at 1000w then it's going to output a total of 1000w, it doesn't matter if you have 1 woofer connected to it or 30, they will divide the power.
yea. the more subs you hookup the more times it's getting divided. if you hooked up 2 subs to an amp that does 1000w, it'll do 500 to each. if it did 1000w to each that'd be free power //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
110
6
354
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
657
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
477
Matt Barnett
Matt Barnett
Evansville,IN
Matt Barnett
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
