Question About 4 Channel Amp Installation
  • 4
acornbean
Car: 2003 accord coupe EX
Stock Component and Rear Speakers
Amp: Alpine MRP F300
Sub: 12" Infinity Sub (not sure which model)
Head Unit: Pioneer FH-X721BT
Ultimate Amp Wiring Kit
Ultimate Amplifier Installation Kit (AMP4) : Car Amplifier Kits - Future Shop
Stinger 17Ft 2 Channel Stereo Interconnect RCA cables
Hey there I tried googling my question and couldn't find a direct answer. I did stumble upon this site and saw many helpful responses to other people's questions so I thought I'd throw mine into the mix!
Okay I just bought an Alpine MRP-F300 4 channel amp and I was wondering if I need a crossover for it. I want to hook channels 1 and 2 to my front speakers and bridge channel 3 and 4 to my sub. I read somewhere that this amp has "Variable high-pass/low-pass filters" that "let you adjust the frequency output for either full-range speakers or a sub." Can I use the high filter for the front speakers and the low filters (that possible?!) for the sub or do I not use any filters and get a line out converter for the front speakers?
Also, the factory speakers are component, I believe, as they have tweeters (That makes them component??) Would they be powered by the Amp if I hook up the front speakers via one of the 2 sets of RCA pre-outs on my head unit?
Is there anything else I will require for my installation that's not provided by the ultimate amp wiring kit and extra set of stinger RCA cables?
Was planning on on running front speakers and sub off amp and rear speakers of the head unit... That sound like a good way to go? Any recommendations, tips, and answers are GREATLY appreciated! Thanks!!!
Your headunit only has one set of RCAs, and you can either use them as full range outputs or sub-only outputs.
You can connect the HU in one of two ways:
1)
Set HU RCA outs to full-range mode.
Connect L/R RCAs to CH1/2 and CH3/4 input using y-splitters.
Use CH1/2 for fronts and bridge Ch3/4 for sub.
Set Ch1/2 filter to highpass at ~80Hz
Set CH3/4 to lowpass at ~80Hz
OR you can connect this way:
2)
Connect HU front speaker outputs to CH1/2 high-level speaker inputs on the amp (you do not need a LOC, amp has speaker level inputs too).
Set HU RCA outputs to SUB mode and connect to CH3/4
Set amp HP and LP filters same as noted above.
I prefer the second method^ because it retains headunit fader and sub control.
You will be fine running rears off HU. You only want a little fill from rears anyway.
I see it is a 2003 Accord EX. The factory tweeters have their own inline crossover cap so you can connect them to the CH1/2 outs with the midbass speakers without needing anything else.
Here is a pic of your tweets - the capacitor is the little round thing at the bottom so you are good to go.
Your headunit only has one set of RCAs, and you can either use them as full range outputs or sub-only outputs.You can connect the HU in one of two ways:
1)
2)
You're forgeting one important filter. Cutting off the mid around 4k
Thanks for clearing that up!! Do you know if the tweeters would be seperatly wired? Or are they connected to the front speakers? Just wondering if I can just hook up the front and power both
He's using factory front/rear speakers. No need to confuse things for him. Natural roll-off of the factory mid will be good enough for now. Once he blows the factory drivers with the new HU & amp he can get a set of components with passive xover and all is good.
By searching online wiring diagrams, it looks like the tweeter is wired to the door speaker (not separately), so you should be able to make one set of connections to the fronts and both will power up.
You cannot unless you wire the two speakers in series. If you wire them in parallel, that brings the load down to 2 from the speaker and the...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
315
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
681
acornbean
acornbean
Vancouver, BC
Jepalan
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
