Question on Amp and Sub compatability
Hey guys, this is my first post, but I have a question about amps and sub compatibility, because this is relatively new to me.
I'm looking into upgrading my system, specifically buying a new subwoofer. I recently bought two amps off of my friend, both Arc Audio. The first is an Arc Audio ks300.4 that I plan on running to my door speakers, and the second is an Arc Audio ks300.2, that bridges to 700 watts at 4 ohms that I plan on running to my new subwoofer.
With that out of the way, I'm looking into an RE Audio sub. As far as ohms, I don't really get the concept of the number of ohms with the wattage of the amp, and what combination would produce the best sound. I would like to buy an RE SXXv2 sub, but I'm not sure whether to go for the two ohm or the four ohm version? What would be the difference between the two? Can anyone give me an explanation and clear this up? Thanks!
Since your amp is 700 and the sub can handle over 1kw you would be looking to get as much power out of the amp as possible.
That 700w is available at 4 ohms -- so for a dual voice coil sub you'd need a d2. The coils can be wired in series for 4.
http://www.sonicelectronix.com/product/img/subwoofer_wiring/1_sub_DVC_2_ohm_2ch_bridged.jpg
If you went with the d4 you'd have wiring options of 2 or 8. 2 would not be safe for the amp, and 8 would reduce its output to
538
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
bigmak927
bigmak927
Detroit, MI
n2audio
    May 18, 2024
    May 18, 2024
