Question on this amp
  • 4
You can run as many subs off of it as you want as long as you wire them up to stay with in the amplifiers rated ohm loads.
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
521
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
Kool
Kool
Michigan, U.S.A.
Kool
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
