Question regarding cd playback
  • Thread starter Unregistered
  • Start date
  • Replies 0
  • Views 1K
    Participant list
U
Unregistered
Guest
I have a Kenwood KDC-9017 and recently have been having problems with the cd's skipping when the bass hits. It worked fine for about 6 months and I haven't changed anthing since then. Someone told me that it might be a problem of the subs pulling too much power from the battery causing a short gap in the power to the head unit? But I dont know if this makes much sense? I was thinking it might be antishock, but it doesnt really get effected when i hit a bump (well maybe a huge one) or anything. Anyways, any help would be much appretiated.
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
If this amplifier is an aftermarket unit, it should have RCA Output. If it is not, then connect to the rear amplified speakers. The sub amplier...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
556
Guest
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
