Quick Wiring Question on Speakers
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 1K
  • 1
U
Unregistered
Guest
My last speakers (Legacy Plates ls4615) were installed in my car. I'm swapping them out. They have 3 posts on them labeled red white yellow from left to right.
The left speaker had R and W plugged in.
The right speaker had W an Y plugged in.
Is it safe to assume that the W line is negative and the yellow and red are positive terminals?
Please a quick hint so i dont mess things up //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
-James
Oh the joys of a common ground system. You are correct in your thinking if everything is as you say it is. I would however, highly reccomend moving away from the common ground set up and utilizing an independant ground for your system- basically for ease in future installation as well as compatability issues.
take it easy,
-zane
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
i have no experience with component speakers. Maybe someone else can help in this area.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
64
Guest
zane
