quick wiring question?
thats right i remember looking at this a while back ..... thanks man.... i got a little worried for a sec
You would have to figure out if you want to wire them in series or parallel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif hope this helps.
Although i thought Parallel would drop the load, meaning 2 8ohm speakers in Paralell would then be 4ohms, and if wired in series the amp would just send it out to each at what ever the amps ohms is. heres 2 links that explain it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif hope this helps.
Series Vs. Parallel Wiring
http://www.installdr.com/TechDocs/999016.pdf
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
i have no experience with component speakers. Maybe someone else can help in this area.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
64
hansk
hansk
ATL
hansk
