Thats why if you have auto windows you seal up the holes with removable panels so if anything does happen you just pull a few screws and you can work on it like it came from the factory. I usually use 1/8" abs plastic with whether stripping around the edges. Has worked great on all the builds I have done. If you have manual windows like I do though then its not a problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifI did that with my doors. Then my window regular wire frayed. Therefore, I had to remove all the deadener and supplies I used to seal up the doors. IMO unless you are cocky it is not worth sealing the doors for a daily driver just in case you run into any kind of problems with the mechanisms inside your door panel. Competition cars are a completely different story, but that is just my 2 cents.
Factory one but I'm not too worried about it. The box will be getting covered with dark carpet and the truck will hopefully be getting 5% all around. Nobody would be able to really see it unless they know my truck.OP I hope you have a good alarm system on your truck.
Those are the ones you usually have to worry about.Nobody would be able to really see it unless they know my truck.
