Rca help
  • 1
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
952
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
653
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
646
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
576
reddzeppelin
reddzeppelin
Texas
reddzeppelin
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
