RCA splitter out of pass thru?
  • 3
Oldschoolpunch
CarAudio.com Newbie
VA
I have a old school RF 4080 and 2 punch 60 ix. Running 6.5 and 6×9's off 4080 and was going to run 2 12" p2d2 subs off one a punch 60(bridged 2ohm load). I have two punch 60's and was wondering if I can use a RCA (1male to 2 female) adapter out of pass thru of 4080 to run both 60ix's if I choose. The punch 60s dont have a pass thru so..idk.
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
987
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
8
3K
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
780
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
779
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
670
Oldschoolpunch
CarAudio.com Newbie
Oldschoolpunch
VA
Cannonshane
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
