RCA splitter
  • 3
Heide264
I have a pioneer hu which I'd prefer to use in place of my current eclipse one. It only has one set of pre-outs though. I was wondering if there would be any harm in just splitting the one set of pre-outs into 2 so I can run both my sub and door amps. The one amp actually has an optional crossover in it, and the sub enclosure itself has a coil in it. I run the door speakers full band.
See any issues with it?
Thanks, just going to wire it up to my dist blocks and try it out.
Do you mean some amps have rca output as well as input? Are they the same idea as a splitter basically? I know mine don't, one is a 15+ year old USAmps150 and a mid line JBL. Never knew that though, appreciate it.
x2 someone care to confirm?
Okay, can somebody explain, on an older pioneer head unit (DEH-1600), it only supposedly has "rear" preouts... Any truth to this or marketing gimic? I would think a pre-out is a pre-out other than fade control.
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
987
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
8
3K
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
776
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
777
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
666
Heide264
Heide264
Pittsburgh, PA
Heide264
winkychevelle
    May 24, 2024
