Re audio neo comp set
oxsign
No Affiliation
6,046
34
Orlando, FL
1. Product:
2. Specs:
Features:
600 watts total system output peak
300 watts peak each
150 Watts RMS
Impedance: 2 Ohms
12dB/Octave Crossover Network
Rubber Surround
Size: 6.5" component set (2 Ohm)• 12dB/Octave Crossover Network
High Grade Non-inductive Resistors
Tweeter Attentuation Control
6.5" Midbass Driver
Rubber Surround
Foamed Core Poly Cone
Cast Aluminum Basket
FEA Optimized Motor Structure
Split Coil Design
High Linearity Nomex Spider
Extreme Excursion
1" Silk Dome Tweeter
Powerful Neodymium Motor
Swiveling Flush Mount
2 Ohm
Made with some of the same components used to create the amazing XXX series of subs!
3. Description/Condition:
Good used working condition. Used on an AQ 90X4 also for sale here
4. Price: :
$200 shipped
5. Pictures:
A Link would be very helpful. Id be interested in taking a look at some gear
183
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
296
oxsign
No Affiliation
oxsign
Orlando, FL
oxsign
