RE SX 12" bad lead wire
  • 4
944g37
This is my set up but it is unimportant in this question. http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/385439-94-mitsu-eclipse-sx12-2-0-cu.html
I bought my RE SX 12 more than 2 years ago and I ALWAYS play it hard, recently it started quitting. It would play fine for 3 days then stop mid song and not work for a half hour then play fine for another three days. I removed it from the box and looked it over, nothing looked or smelled damaged. I grabbed my ohmmeter and started hunting. One of my coils measured 2.1 ohms, one was O/L. I wiggled the lead wires going from the terminals to the cone and started getting an intermittent reading. So I removed the dust cap and started measuring where the leads are soldered to the coils it measured fine there. Long story short the lead was burned internally where it hooks to the terminal from being stretched at a 90* angle when the sub is moved all the way out. It looks like it was too short from the factory. The other lead on that side looks too long and is wearing a hole in the spider. For now i cut the lead off above where it was burned, pulled it through the terminal and re-soldered it then bent the terminal closer to the cone to try and make sure it didnt run out of wire at full excursion.
My questions are: is this a common problem, how and with what do I replace this wire when it breaks again, how and with what do I glue the dust cap back on, (the center of the RE is like 2" in dia. so now I have a massive air leak).
dont play ur sub with the dust cap? cone cover off it greatly reduces the powerhandling thermally.
if you have worn a hole in the spider its time to recone anyway and have stiched leads...
You can re-run new leads from under the dustcap. You'd have to get the glue off the old connections, get the old leads out, run new wire at the proper length, glue them to the back of the cone, then re-dustcap it.
We sell caps that fit the SX. You could cover the old one with the new cap. We also sell leadwire, solder, glue, etc.
You'll need CA glue and some sort of contact cement for the dustcap. We also well both of those.
Expect to spend $40-50 to repair it yourself.
We will repair it for $50.
Or recone it for around $100 and have a brand new sub, sewn leadwires, etc...
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
944g37
944g37
Vassar, MI
TeamPSI
    Jun 1, 2024
    May 31, 2024
