Recommended amplifier for these subs?
goodmusic
23
Fla
I'm going to be buying these subwoofers:
2 Rockford Fosgate P2D4 12 12" 1000W Car Subwoofers 080687324606 | eBay
Theyre both 4 Ohms, so I think im just wire to them a 1omh final. Using this:
What amplifier would provide more than enough power for these subs? I want them to really really kick. I used to have an audiobahn a8002t for some only p2's and they kicked so hard. Im sure that these new ones will kick even harder since the previous had an RMS of 200 and these are 400.
Any help is appreciated!
Oh and Im going to have to drill a hole through the middle of the box on the inside. Does anyone know where I can get a roll of pos/neg jumper wire long enough to wire it all?
Thanks in advance!!
I found these speaker wire site, so all I need is help picking a amplifier. Im sure I need 1000+ watts, and then, what gauge of speaker wire to buy
Car Speaker Wires at Sonic Electronix
The subwoofers would have enough power to sound loud with the 1ohm to the amp right? Or am I gonna have to do a dual 4 ohm to 4 ohm on the amp to really get them to kick hard?
THanks in advance
this amp will work, do the 1 ohm Precision Power PPI S850.1D Sedona Series 850W Class-D Monoblock Amplifier
you can go with 12ga - 14ga speaker wire.
just so you know each sub takes 400 rms so 2 subs take 800 rms.
Im not looking to buy chrome again. It gets way too hot. And I run my amplifier sometimes for 2-3 hours on long drives. Im willing to waste up to like 175 on an amplifier that will drive the subs to peak and not overheat or die out on me
The next model up on the precision amp would probaly be good and almost exactly your budget
Im looking for an amp that will last. Link?
I want a reputable brand. The subs are 4ohm, ill have two. So I plan on wiring them to 1ohm. Whatever amp you think can handle the 800RMS+ for both combined, and the 1600 watt peak for both, suggest it. Id be willing to waste up to 200.00 on a amp that will last me
Are you talking about this one:
Precision Power PPI P1000.1 Phantom Series 1000W Monoblock Amplifier
The thing is, I would wire them to 1ohm. And by doing that, I would be left with one positive and one negative only. Meaning I would have to bridge, and I cant bridge according to the specifications of that sub.
Right?
Use this tool as a guide to wire subs:
Rockford Fosgate® - Woofer WiringWizard
The soundqubed 1200W would be good for those, give you some headroom and it's $269.
I've read a lot since I made this thread and I've learned way more than expected. I'm going to wire them to a 1ohm impedance. Im going to buy a mono amp. I've made up my mind and brought it down to these two:
Pioneer GM-D8601 Monoblock 800W GM Digital Series Class-D Amplifier
I like the precision power way more, but the thing is, it says 1000 watts RMS @1ohm with 14.4v, and only 785 RMS @1ohm with 12.2v. The subs alone are 800watts RMS. What do you guys think? And most likely my battery is ranging way under 14.4v, meaning I wouldnt get the full RMS
12 volt = battery only. car off.
14 volt = car running. alternator making power.
Either one of those amps will push those P2s. Rockford has a 1200 watt in their prime lineup that would match up nicely too.
12 volt = battery only. car off.14 volt = car running. alternator making power.
If you had to recommend the pioneer or the precision power, which would you pick? Im leaning more with the precision power. All the extra knobs give me better control over everything.
---------- Post added at 09:10 PM ---------- Previous post was at 09:09 PM ----------
If you are really willing to spend a little more we could do a Incriminator 10.1 Can not go wrong with that amp. Can also hook ya up with the wire if needed.
How much more is a little more?
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
5
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
You need to accurately and carefully measure your trunk out, and decide how much space you want to use, too. Always measure your trunk out before...
12
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
404
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
goodmusic
goodmusic
Fla
goodmusic
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
