Remote Starts
showtm490
35
GA
I've been looking around for a remote start for my 2011 Toyota Sienna SE. Different places all have different answers it seems and some say they need to look into it. Here's what I'm looking for, a two way remote start that'll let me open my side doors and truck. On the stock Toyota when it's running the remote doesn't work so I'm told a bypass is needed for the aftermarket setup to make that work. Also the headlights come on automatically but once you turn the van off they remain on until a door is opened. I was told a bypass would work there also to turn the lights off. What recommendations do you have?
I've seen these....
Viper 5706V, 5906V, 4806V, 5210V, SmartStart
Drone Mobile
Compustar 9000, 704, 901, CS7102AS
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
621
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
showtm490
showtm490
GA
showtm490
    Jun 1, 2024
    May 31, 2024
