Replacing alternator
  • 2
depends on location of the alternator but usually not hard at all, remove the belt, remove 2-3 bolts / remove wires to alternator first tho before hand.. also disconnect battery first
Yeah... just disconnecting, battery first + & - , remove cables from alternator, remove belt, remove all bolts and bracket if there is one on it (depends on where its located to make it easier to mount back up) repeat process in reverse to install new alternator
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
At the end I decided to take the dashboard out, since I also had to solve a problem with the heater core. Upon inspection, I could not find any...
10
MANTI5
MANTI5
Southern AZ
MANTI5
    May 18, 2024
    May 18, 2024
