RF Power 800a4 and Audio Control EQX
  • 2
Tim Schroeder
Hello, I have a Rockford Fosgate Power 800a4 and trying to use an Audio Control EQX Concert series processer. I have an Audio Control EQX Series 2 and an Audio Control EQX Concert series. The EQX Series 2 works fine but the EQX Concert series will not make a sound. I have hooked the EQX Concert series to 2 200a4's and a 400a4 and it works fine. Both work with the other 3 amps. The EQX Concert series will not work with the Power 800a4. Does anybody have any idea what might be going on.
I have tried it both ways. The concert series I bought new from Audio Control. Series 2 used. I had this amp and Concert series in another truck with a bd1000a1 and a 200a4. Also had a 6xs 3 way crossover concert series in that system.
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line converter in and hooked both up line level and had the same results. No sound out of the Concert Series. I've bypassed all speaker wires one at a time to make sure a wire isn't pinched or something wrong and nothing changes.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
532
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
394
806
Tim Schroeder
Tim Schroeder
Lewisville Texas
Tim Schroeder
    May 12, 2024
Brendon Jenness
    May 11, 2024
