Rockford Fosgate 800.2
  • 2
nutxo
tacoma
Fully functional beast 2 channel. Most of the birthsheets Ive seen for these have em at 1000 watts bridged into 4 ohms.
400 watts x 2 at 2 ohms
800 watts x 1 in bridged mode
stereo, bridged mono or Tri-Way output
50-210 Hz high-pass/low-pass crossovers, 12 dB/octave
wired remote control included for fingertip control of Punch Bass (boosts bass 0-18 dB, centered at 45 Hz)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker-level inputs
60-amp fuse and fuse holder required
dimensions: 18-7/16"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
The power led doesnt work but I had it tested by a local shop and the amp is fully functional.
150 shipped USPS flat rate box
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
nutxo
nutxo
tacoma
nutxo
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
