Rockford Fosgate 800a2 w/gut shots (Clean/Old School)
  • 4
1EdgeKilla
-Rockford Fosgate 800a2
-No Endcaps
Item(s) Condition:
Mechanically: 10/10 (this line of amps were tanks)
Cosmetically: 9/10 Amp is VERY clean compared to some i've seen (see pics)
-New Speaker & Power Terminal Screws
-Inside Is BEAUTIFUL!:surprised:
Item(s) Specs:
13.8v:
200 x 2 @ 4 ohms
400 x 2 @ 2 ohms
800 x 1 @ 4 ohms
14.4v
240 x 2 @ 4 ohms
480 x 2 @ 2 ohms
960 x 1 @ 4 ohms
60 Amp fuse
S/N ratio: >100dB
damping factor: >200
IMF distortion:
-Not in a hurry to get rid of so $180 plus shipping or $200 shipped whichevers cheaper
-I've seen ones in horrible shape go for almost as much
-No Trades Unless Highly In My Favor
-Prices Firm
-Lower 48 Only
-UPS Ground
-Buyer Pays If Insured
Great amp! I would consider buying this but my subs are S4, and wouldn't get enough power from this //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif GLWS & Free bump!
so it was brought to my attention earlyer today that the resistors in the bottom right hand corner of the amp looked burnt. To my embarassment I totally overlooked this and after taking a second look at the pictures thought so myself. So to be sure I opened the amp back up today and checked them to see and turns out the resistor is bad. That channel on the amp still works though which is the weird thing. Anyhow, I soldered out the bad resistor and checked the others. The one next to it was still good but was slightly burned as well so I removed that one also. I will be heading to the electronics store tomo to pick up new ones and will be replacing them and will post new pictures with the new transistors once I'm finished as well as a linked video of the amp working if need be for it to sell. I appologize for this as once again I totally over looked this somehow but by all means sorry.
Thanks and sorry again.
Edge
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
1EdgeKilla
1EdgeKilla
Williamsport, PA
1EdgeKilla
