Rockford Fosgate P300-2 channel Amp
  • 1
DMP
This is a 2-channel amp rated at 300 watts RMS. The birth sheet included actually says 377 x 1 @ 4 ohms, so it does produce more power than 300 watts RMS. This was installed in a project vehicle that I am now selling, and I removed all the audio equipment from it. This wasnt even used for more than 15 mins. You will not be disappointed with the condition and this would be better than buying a refurbished one.
$125 shipped in the U.S.
Accepting Paypal ONLY.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
DMP
DMP
North Jersey
DMP
    May 16, 2024
    May 16, 2024
