SOLD Rockford Fosgate power amp
kurtbeast
Florida
Hello all, i have a rf power 4 channel(t4004) amp for sale. It is in excellent condition with just one scratch on it, no big deal though.. This is the old style and is extremly underated! Most of these do between 90 and 100 watts per channel at 4.
125 OBO
Heres the specs
•4-channel car amplifier
•25 watts RMS x 4 at 4 ohms (50 watts x 4 at 2 ohms)
•200 watts RMS x 2 bridged output at 2 ohms (2-ohm stable in bridged mode)
•variable high- and low-pass filters (40-400 Hz at 12 dB per octave)
•ParaPunch bass boost (0-18 dB, variable 35-70 Hz) with wired remote
•Tri-way capable (Tri-Way crossover required)
•MOSFET power supply and output stages
•CEA-2006 compliant
•preamp inputs and outputs
•fuse rating: 40A x 2
•4-gauge power and ground leads with 80 amp fuse recommended — wiring and hardware not included with amplifier
•16-1/4"W x 2-5/16"H x 12-3/4"D
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
kurtbeast
kurtbeast
Florida
matt_bennett05
    May 24, 2024
    May 23, 2024
