Rockford Fosgate Punch 1000x5 Channel amp Help
dab86
Question,
I have the P1000x5 Amp.....The specs for the amp are below.....All numbers are RMS. Can I get 700 watts out of the sub channel if I wire each 4 channel to 75 watts @ 4 -ohm (Total of 300) and the sub channel to 1 ohm? Or is the sub channel limited to only 500 watts no matter what?
I figured if you subtract the door speakers (300) from 1000 you are left with 700? Not sure if it works that way or not.
I am powering two 10 inch P3 Subs
RockFord Fosgate Punch 1000x5
75 Watts x 4 + 150 Watts x 1 @ 4-Ohm
125 Watts x 4 + 300 Watts x 1 @ 2-Ohm
N/A + 500 Watts x 1 @ 1-Ohm
That *****. The amp is already installed and running my system. The subs are rates 500rms each so 1000 rms total. They are only half powered //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Could I buy a mono 1000 amp and run it along with the 5 channel? Jus disconnect the sub channel on the 5 channel?
Yes
yes.. but what subs do u have? let us help u pick an amp so u don't have more problems.. those 5 chan amps normally work best for single sub set up..
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
dab86
dab86
Pittsburgh, PA
BOOMINGRANDPA
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
