RockFord fosgate punch 45
The first system I owned (waaaaay back in the late 80's) used two RF Punch 45's. One handled a set of RF Punch Plates for mids/highs and the other one powered 4 Kicker 10" Free-Air subs. The system sounded "OK" but, could have sounded much better with alittle work on isolating the IB setup of the subs. I'm pretty sure the gains were maxed out on the Punch handling the subs LOL! But, it never failed. Got really hot but, never died on me.
I like seeing people do more with low powered setups. It's awfully easy to just go out and by a garbage mon-block and distort the crap out of the speakers. Takes some real planning to do low-power and sound good.
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
ajramirez1995
ajramirez1995
Chicago, IL
PPI_GUY
    May 31, 2024
    May 24, 2024
